Getting Surface LIC representation through python script
Hi, I am postprocessing an OpenFOAM CFD simulation in ParaView using python script and paraview tracer. I want to obtain slices with total pressure coefficient plots (managed to get this working ok) and velocity LIC. Unfortunately I am struggling to change slice representation to Surface LIC - all the plots I am getting from this script use “Surface” representation.
Scroll to line 274 to see how exactly I am trying to switch to LIC.
If you have any ideas on how to troubleshoot this I’d really appreciate help!
Regards!
postProZ_v1.py (8.2 KB)
I tried a simpler script that seems to work perfectly on paraview master.test.py (5.5 KB)
Hi Mathieu,
Thanks for getting back to me!
  1. When I try to just run your script I get a message
File “test_LIC.py”, line 36, in
wavelet1Display.GaussianRadius = 0.1
File “/usr/lib/paraview/site-packages/paraview/servermanager.py”, line 453, in setattr
“to add this attribute.”)
AttributeError: Attribute GaussianRadius does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute.
  1. I tried following your advice though and modifying my original script to use
slice1Display.SelectInputVectors = [‘POINTS’, ‘U’]
slice definition, however this also results in the following error:
File “postProZ_v1lic.py”, line 237, in
AttributeError: Attribute SelectInputVectors does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute.
Any ideas how to troubleshoot this?
Thanks,
OlekpostProZ_v1lic.py (7.8 KB)
I’m sorry, I always forget that generated python script are not retro compatible.
With which version of ParaView are you working ?
Hi Mathieu
I have 5.4.1 64bit, running on Ubuntu
Olek
Here is a working python script for ParaView 5.4.1
test.py (3.0 KB)
Thanks, managed to get it working now :slight_smile:
