I’m getting this issue in ParaView 5.10.1 where the rendering appears patchy, especially when zooming/ panning. Any idea why this is happening and possible fix?
Welcome to the ParaView community, @girindra . It looks like your data has two surfaces right on top of each other. These surfaces “fight” to be displayed, hence the shifting pattern you see.
If this is a multblock dataset, you can try using the MultiBlock Inspector to turn off some of the data. Without knowing more about your dataset, I can’t give much helpful advice.
Hi Cory,
Many thanks for that suggestion. I realised I turned on two mesh layers which coincided. Turning off one of them solved the problem.
