GlyphLegacy issues
paraview_error.txt (3.1 KB)
I have a c++ library that I use, which outputs my data to be read in Paraview.
I have just upgraded Paraview to 5.10.ish and I think my c++ library has a different set of parameters.
I get this error that
(filters, GlyphLegacy)  has been deprecated in ParaView 5.6 and will be removed by ParaView 5.7.
        It has been replaced by 'GlyphWithCustomSource'. Please consider using that instead.
I have attached the complete list of errors when I load my psvm state file.
Any ideas what to do?
It’s a warning, the error is:
ERROR: In ./VTK/Common/Misc/vtkFunctionParser.cxx, line 1226
vtkFunctionParser (0x55f652830d40): Syntax error: expecting a variable name;  see position 5
Please share the pvsm file
Cant believe I am taking this long to reply.
20230719_T6SS_FourState_Capsules_V4.pvsm (1014.7 KB)
Please share the data as well.
chaste-paraview.zip (1.6 MB)
Thanks.
I am happy to learn, I have found the jumping off point for paraview elusive.
In your multiple “Calculators” filter, you need to add quotes around the field names.
eg:
Cell orientation"Cell orientation"
Corrected state file:
20230719_T6SS_FourState_Capsules_V4_kw.pvsm (1.2 MB)
Thank you for that. That helps.
Though when I load it on my M1, I get these errors.
paraview-5.10.1-loaderror.txt (11.7 KB)
No idea then, try using the calculator array name shortcut instead.
