I compiled Paraview using the following configuration in a cmake file. After a successful compilation, I got the following error:
Got unknown argument: --egl-device-index=0. Could you have misspelled your Python file path or name?
Here is the configuration of my Paraview build put in a cmake file:
# General build settings
set(CMAKE_BUILD_TYPE_paraview Release CACHE STRING "")
set(BUILD_SHARED_LIBS ON CACHE BOOL "")
#set(CMAKE_INSTALL_PREFIX /mnt/lustre/phy3/phyalan/paraview-cray/compiled CACHE PATH "")
# Enable the appropriate packages
set(ENABLE_boost ON CACHE BOOL "")
set(ENABLE_bzip2 OFF CACHE BOOL "")
set(ENABLE_cosmotools ON CACHE BOOL "")
set(ENABLE_ffmpeg ON CACHE BOOL "")
set(ENABLE_fortran ON CACHE BOOL "")
set(ENABLE_freetype ON CACHE BOOL "")
set(ENABLE_genericio ON CACHE BOOL "")
set(ENABLE_hdf5 ON CACHE BOOL "")
set(ENABLE_lapack ON CACHE BOOL "")
set(ENABLE_libxml2 OFF CACHE BOOL "")
set(ENABLE_llvm ON CACHE BOOL "")
set(ENABLE_matplotlib ON CACHE BOOL "")
set(ENABLE_mpi ON CACHE BOOL "")
set(ENABLE_numpy ON CACHE BOOL "")
set(ENABLE_osmesa OFF CACHE BOOL "")
#set(mesa_SWR_ARCH "avx,avx2" CACHE STRING "")
set(ENABLE_ospray OFF CACHE BOOL "")
set(ENABLE_paraview ON CACHE BOOL "")
set(ENABLE_paraviewsdk ON CACHE BOOL "")
set(ENABLE_paraviewgettingstartedguide ON CACHE BOOL "")
set(ENABLE_paraviewtutorial ON CACHE BOOL "")
set(ENABLE_paraviewtutorialdata ON CACHE BOOL "")
set(ENABLE_paraviewusersguide ON CACHE BOOL "")
set(ENABLE_png ON CACHE BOOL "")
set(ENABLE_python ON CACHE BOOL "")
set(ENABLE_python3 ON CACHE BOOL "")
#set(ENABLE_python2 OFF CACHE BOOL "")
#set(ENABLE_qt OFF CACHE BOOL "")
set(ENABLE_silo OFF CACHE BOOL "")
set(ENABLE_socat OFF CACHE BOOL "")
set(ENABLE_szip ON CACHE BOOL "")
set(ENABLE_scipy ON CACHE BOOL "")
set(ENABLE_visitbridge OFF CACHE BOOL "")
#set(ENABLE_vortexfinder2 ON CACHE BOOL "")
set(ENABLE_vtkm ON CACHE BOOL "")
set(ENABLE_xdmf3 ON CACHE BOOL "")
set(ENABLE_zlib ON CACHE BOOL "")
set(PARAVIEW_PLUGIN_ENABLE_pvNVIDIAIndeX ON CACHE BOOL "")
set(ENABLE_nvidiaindex ON CACHE BOOL "")
set(ENABLE_glproto OFF CACHE BOOL "")
set(ENABLE_egl ON CACHE BOOL "")
set(VTK_USE_OFFSCREEN_EGL ON CACHE BOOL "")
#set(PARAVIEW_DEFAULT_SYSTEM_GL ON CACHE BOOL "")
set(VTK_USE_X OFF CACHE BOOL "")
set(VTK_OPENGL_HAS_EGL ON CACHE BOOL "")
#set(ENABLE_cuda OFF CACHE BOOL "")
# Work around cmake bug, which values from `which cc,CC,ftn`
set(MPI_CXX_COMPILER /opt/cray/pe/craype/2.6.1/bin/CC CACHE STRING "")
set(MPI_C_COMPILER /opt/cray/pe/craype/2.6.1/bin/cc CACHE STRING "")
set(MPI_Fortran_COMPILER /opt/cray/pe/craype/2.6.1/bin/ftn CACHE STRING "")
# These will get pulled from the compute node's userland
set(USE_SYSTEM_boost OFF CACHE BOOL "")
set(USE_SYSTEM_bzip2 OFF CACHE BOOL "")
set(USE_SYSTEM_freetype ON CACHE BOOL "")
set(USE_SYSTEM_hdf5 ON CACHE BOOL "")
#set(VTK_USE_SYSTEM_HDF5 ON CACHE BOOL "")
set(USE_SYSTEM_lapack ON CACHE BOOL "")
set(USE_SYSTEM_libxml2 ON CACHE BOOL "")
#set(USE_SYSTEM_llvm ON CACHE BOOL "")
set(USE_SYSTEM_matplotlib OFF CACHE BOOL "")
set(USE_SYSTEM_mpi ON CACHE BOOL "")
set(USE_SYSTEM_numpy ON CACHE BOOL "")
set(USE_SYSTEM_osmesa OFF CACHE BOOL "")
set(USE_SYSTEM_png ON CACHE BOOL "")
set(USE_SYSTEM_python ON CACHE BOOL "")
set(USE_SYSTEM_python3 ON CACHE BOOL "")
set(USE_SYSTEM_zlib ON CACHE BOOL "")
# ParaView details
set(SUPERBUILD_PROJECT_PARALLELISM 24 CACHE STRING "")
set(paraview_SOURCE_SELECTION 5.7.0 CACHE BOOL "")
# Specify where the necessary tarballs have been downloaded to
set(superbuild_download_location ${CMAKE_BINARY_DIR}/../../downloads CACHE STRING "")
# Another, ensure we get cray python
set(PYTHON_EXECUTABLE /opt/python/3.6.5.7/bin/python CACHE FILEPATH "")
set(PYTHON_INCLUDE_DIR /opt/python/3.6.5.7/include/python3.6m CACHE PATH "")
set(PYTHON_LIBRARY /opt/python/3.6.5.7/lib/libpython3.6m.so CACHE FILEPATH "")
set(superbuild_python_pip /opt/python/3.6.5.7/bin/pip CACHE FILEPATH "")
PS: I was trying to build Paraview in offscreen rendering mode with EGL on headless nodes to use the cluster variant of Nvidia IndeX
