grabbing loaded data from shell
in 3d slicer there is a way to grab data that is already loaded with the grabNode() function, is there a similar function in paraview where you can interactively grab a loaded dataset and apply other vtk filters to it?
this in the context of using the python shell along with the gui.
This is a task for servermanager.Fetch, be aware that it can be expansive to call it in some cases.
from vtk import *
s=Cone()
object = servermanager.Fetch(s)
writer = vtkXMLPolyDataWriter()
writer.SetInputData(object)
writer.SetFilename("test.vtp")
writer.Write()
this is helpful but when I say loaded I mean loaded via the gui. not the python shell.
an example would be to access the origin of a triangle surface that was already loaded via the gui and get the object as a python object in the shell.
The python shell is compatible with the GUI.
In the GUI, in the Pipeline Browsser, click on the source you want to examine, then :
s = GetActiveSource()
