Hi everybody ! enjoy your sunday !
Some time when I have to post process a polymer (using spherical glyph as atoms and tube for the virtual connection) if the polymer chain going to collapse and the atoms are very close each other I have to reduce the ray of the glyph sphere I don’t obtain a good sphere but a rough approximation like in the pictures
drudox00,
I don’t know. However, I would guess that this is not a graphics card issue. If possible, please add an example data file, with steps to reproduce the issue.
Alan
If I had to guess (and this is just a guess without more information) is that your data takes a very small region of space (somewhere around of 1e-130). The coordinates get stored fine in double precision, but the graphics system has to convert the double precision to single precision, and single precision floating point numbers cannot hold numbers that small with precision.
I would try running the Transform filter and scaling up the physical space by a large number to get the bounds closer to 1.
I tried loading your data into ParaView 5.6, and it worked fine. I then tried again in an older version of ParaView (5.2) and saw rendering issues similar to what you report. So my first suggestion is to update to the latest version of ParaView if you can. That might solve the problem for you.
I notice that your data has bounds around 100 wide but is offset by around 10 million. If you cannot update your version of ParaView, you could try translating your data to center around 0. Add the Transform filter and change the Translate field to [ 79781000, 62944000, -14140000 ]. That solved the issue on my computer with ParaView 5.2.
There is only one version of ParaView 5.6 binaries. With ParaView 5.4 there was a transition from an old legacy OpenGL to more modern OpenGL features. By ParaView 5.6 the old legacy OpenGL support was dropped.
Not really …
when I translate the data does it metter if i leave selected the marks options ‘scale’, ‘rotating’ and of course translate ? I left the value of scale = 1 ,1,1 ; rotate = 0 , 0 , 0
No, leaving scale and rotate the same is correct. Are you doing the translate before the glyph? It shouldn’t matter, but it might.
Some other things you can try is to turn on OSPRay rendering. (The option is on the bottom of the View properties.) That will turn off any graphics hardware you have. If that does not change the behavior, then the problem is probably not with the rendering.
