Guidance for writing VTKHDF files with data time series
I’m trying to write VTKHDF files with time series results. I found some examples online but to say they are cryptic is an understatement. Naturally, no actual files are made available to play with. I took your can crushing example and saved it as a VTKHDF file in the hopes I could figure it out from the data structure. However, I don’t believe the full time series is written. Also, when I read the VTKHDF file back in to Paraview in a fresh session I get several errors, and no time history, so I suspect your writer is buggy. I’m using Paraview version 6.2.0. If any of your team has a simple example file with a single unstructured grid geometry with a short point data time history response (no blocks or any other fancy stuff) you can share please post in the response. I can take it from there. Thanks,
