Dear all,
I’m trying to use the Python script to set plots. I started trace and got some codes of the operations. When I wanted to modify the codes, I could not find the detailed help documentations of the functions. I tried help but the results did not give much useful information.
Hi Mathieu,
Thanks for your reply. I tried the link but I didn’t find the description of “AxesGrid”.
I want to set where to show the labels and what to show. For instance, I want to show 0, 100, 200 at x= 0, 10, 20.
I’m used to use code to control plots in matlab, so I want to trace the Python script and modify it in ParaView. But I can not find the detailed help documentation of the functions used in the python script.
What do you mean “AxesGrid is not related directly to plots in ParaView”? Are these functions in Python? I’m confused about the relationship between Python and ParaView
There is a Y axis infront of the rendered volume after I set the “Data Scale” in “Axes Grid”. Why does that happen? How can I remove the infront Y axis? Following are the screen shots of this problem
I’m sorry, maybe “plot” is ambiguous here. I am trying to generate 3D view volume rendering. I want to remove the infront upper Y axis in the view. I also want to use python script to control the 3D view including axis labels and other state.
