Higher versions of paraview do not display colors when drawing VTK files
In the MAC system, I installed version 5.9 and above. After testing, I found that the color cannot be displayed when the image is closer, but only white. Is this a bug or does the new version need some settings? I present this in the attached videos and images. Look forward to your help!
Looks like normal issue with your dataset, please share it.
This is the VTK file I used to draw. Please refer to
7890.vtk.zip (2.5 MB)
Your dataset is very small and this is causing issues with the rendering. Use a transform filter with 1000 scaling in all axes to workaround this issue.
That is great! This solves the problem! Thank you very much for your help!!
