Probably it is a very simple question but I have not found the answer on google or documentation.
Can I highlight (putting markers) some points in paraview?
I am post processing a room and I want to mark points where I took measurements
You can use PointSource to create a point desired position. Or you can use other sources (sphere, cone) to create other objects at desired positions.
Or you can use ProgrammableSource to create a polydata with all your points.
Dan
Thanks a lot. This is what I was looking for
