How can I make Paraview use more RAM ?
I am using Paraview 5.11.2 with Linux Ubuntu 22. I have 64 Go of RAM on my computer.
I am trying to make time steps animation with large vtk dataset 790 MB each, the group is composed of more than 100 files.
Unfortunately, it seems to be too heavy for my computer, and at the bottom right and on the memory inspector, I can see only : “System total 5.07 Gio” and Paraview 1.04 GiB.
I wonder if and how I can make Paraview to use more RAM ?
Thank you for your help,
Regards,
Nina
This is not coherent, what is the output of free -h ?
Here is the answer of free -h while playing the animation :
total used free shared buff/cache available
   Mem:           125Gi       4.3Gi       113Gi        62Mi       8.5Gi       120Gi
   Swap:          8.0Gi          0B       8.0Gi
Indeed I made a mistake I have 125 Go of RAM, not 64.
And here is the memory inspector in Paraview : System Total : 4.21 GiB Paraview 693.5 MiB
I only have linux on this machine.
Ok, so I understand what you mean by “System Total” now.
Well, ParaView should be able to use all of your RAM, what makes you think it does not ?
Thank you for your answer.
Actually, I don’t think I fully understand what “System Total” refers to.
I feel like my computer isn’t making full use of the available RAM, as playing the animation is extremely slow: each frame takes around 20 seconds to display, and Ubuntu keeps popping up a message asking whether I want to wait or force quit ParaView.
I would have expected my computer to be able to use more than 5 GB of RAM before struggling to handle the animation. Could there be another limitation preventing ParaView from using more memory? On the other hand I know that one CPU is fully used during this processus.
I wonder how I can play this heavy animation.
It correspond to your system current usage of RAM.
Your bottlenek is not RAM, its probably IO, please share your data.
Add a temporal cache filter to cache the animation, it will use more ram and speed up drastically once fully read once.
Thank you for your answer. Here is a sample of my datafile
Mydata
vtk DataFile Version 2.0
ASCII
DATASET RECTILINEAR_GRID
DIMENSIONS 251 251 251
X_COORDINATES 251 float
1.00000E+00
VECTORS Velocity float
7.92247E-04-2.51789E-05-2.19898E-05
I will also try to use a temporal cache thank you
Ascii VTK is very inneficient format, you may want to change to another format.
ok thank you, should I switch to binary or to another type ?
VTKHDF would be my recommandation.
Thank you Mathieu. I’ll also try to switch to this.
Have a great day,
I switched to vtkhdf and now it works increadibly well, thank you.
