Could i select an element in gui, and then plot its vm stress over time?
Hi Ning,
Yes there is, select the block or element, Extract it, then select the filter Plot Data over Time, select the data that you would like to show within the plot(vm stress in your case). I hope this is what you were asking.
-Phil
Thank you Phil. That’s very helpful. This process is quite slow to switch between different elements. I am using copy active selection, and apply. It takes very long time to replot curves between each element. Is there any trick to make it faster or plot
