How do I make a illustration of particles in a tube?
Hi all,
I am currently working on a code in openFOAM which simulates a spray through a cylindrical tube. I have successfully imported the data into paraview but am having trouble creating the types of images and graphs that I want. Attached below are examples of what I am trying to create. The dots represent the spray droplets with UX UY UZ being velocity and d being diameter. I have a multi-block data set.
I am using Paraview 5.4.0 64-bit (Legacy Rendering Backend) and am in a position where I cant use any other version. Any guidance or assistance on how I would recreate these images would be greatly appreciated.
Thanks!
Cal
Well, what have you been able to generate so far ? Can you share a example of your data ?
it’s really nice plot!
Hey thanks for the reply. Attached below is what I have so far (Render view and spreadsheet view).
Can you please pin point which tutorial you follow in OpenFOAM?
I can have a try.
You will have to extract the droplets, perhaps using Threshold or Contour.
Hi I have received this case from someone else for my thesis and it deviates a lot from the tutorials, but it uses the sprayFoam solver within openFOAM which I believe is the aachenBomb tutorial.
Good luck :slight_smile:
Thanks for the suggestion, I will try this now :smiley:
Commit search results · GitHub
→ NULL
I think this is it
I will play with it.
Please comment anything if you like.
Hi all,
Update on this, my issue was that the Lagrangian data was not being displayed. I have solved this by converting the data to VTK format using the foamToVTK conversion with the mpirun command as my code was run on multiple processors. I now have the lagrangian data displayed, but the positions of the data is incorrect. Below you can see that the data is mainly located on the z-y plane when it should be displaying throughout the volume of the cylinder:
From the spreadsheet view you can see that all of the x-coordinates in the Position0 heading are all really small numbers (1x10^-22) which is why the data is mainly on the z-y pane. However the position coordinates under the points heading are distributed throughout the volume of the cylinder.
I’m not sure why the data is displaying the way it is:
  1. could it be an issue with how the data was converted to VTK format?
  2. should the position of the lagrangian data be determined by the position0 heading or points heading?
Yes, but you will have to ask OpenFOAM about that.
You can try that easily by using the Calculator filter and the “Results coordinates” checkbox.
Thanks again for the reply!
I’m currently attempting this but I’ve never used the calculator function before.
I tried this: coordsXiHat+coordsYjHat+coordsZ*kHat
but nothing changed and I cant see any new data in spreadsheet view.
What should I input to have it display the solution using the points vector data instead of position0 vector data?
Use position0 as your calculator function and check the “Result Coordinates” checkbox.
