How do I measure the surface area of a vtk file in ParaView
Hello Everyone.
I have a number of .vtk files that make up the surfaces of a tetrahedral mesh. I need to measure the surface areas of a number of these .vtk files. Using ParaView 5.6.0, and following the procedure outlined within this thread, I was not able to find the surface area calculations I need. Does anyone here know how to properly calculate the surface areas of a .vtk file’s surface? Note that I can provide a sample file if necessary.
Thanks for your help!
Welcome to ParaView, @meng!
The Integrate Variables filter will give you the surface area when applied to a polygonal dataset. When you apply it, a SpreadSheet View will open showing you the integrated data values.
Change the Attribute to “Cell Data” and you will find the surface area in a column with the heading “Area”.
For a volumetric mesh, you can get the total volume using the same approach. Look for “Volume” instead of “Area” in the SpreadSheet View if you apply this to a mesh.
Thank you for the help, cory.quammen!
Hello everyone,
is there any possibilities to calculate the surface area of an stl file in Paraview?
kind regards,
Arghavan
Yes. ParaView can read stl files, and @cory.quammen’s instructions will work on an stl file (or any other surface).
thank you for your reply, I could do that. but I am getting the same value of the surface area in each plane. is it correct? or maybe surface area has difference with projection area. actually I want to get the projection area of the stl file.
best,
Arghavan
I don’t understand your question. The Integrate Variables will simply compute the area of each triangle in the stl and then sum those up. I don’t know what planes or projections have to do with any of that.
Thank you for your reply, The problem is solved.
Thanks for sharing this. I find it is useful you have a projected 2D plane mapping from a *.stl file, which is useful in external aerodynamic analysis.
