How does one enable COSMOTOOLS in 5.9.1?
Hello there
Am having an issue compiling the COSMOTOOLS.
So, it seems that PARAVIEW_PLUGIN_ENABLE_GenericIOReader is enabled by default, and that is good. It compiles OK on my first compilation. Then I configure a second time and set PARAVIEW_ENABLE_COSMOTOOLS=ON
and the configure fails with:
Could NOT find GenericIO (missing: GENERIC_IO_INCLUDE_DIR
GENERIC_IO_LIBRARIES)
this seems incongruous since it was able to compile GenericIO on the first pass, but it does not know where to find it on a second pass? :roll_eyes:
my attempt to set it
GENERIC_IO_INCLUDE_DIR=src/Plugins/GenericIOReader/Readers/LANL/GIO
GENERIC_IO_LIBRARIES=build/./lib/paraview-5.9/plugins/GenericIOReader/libvtkGenericIOReader.so
let me go past the configure step, but compilation fails.
Any hint would be appreciated. TIA.
I reproduce, but I’m not sure this is actually an issue. You safest bet would be to try with the superbuild and see how it is configured.
FYI @ben.boeckel
there’s quite a bit of footwork to do, but here is the recipe:
PARAVIEW_PLUGIN_ENABLE_GenericIOReader:BOOL=OFF
PARAVIEW_ENABLE_COSMOTOOLS:BOOL=ON
you must compile a version of GenericIO outside of ParaView. The source is here
unzip genericio-master-a15ffc76cfa9f9674f933e8cb5ffc97a97fd7b27.zip
cd genericio-master-a15ffc76cfa9f9674f933e8cb5ffc97a97fd7b27/
that version is missing installed rules and it must be patched
the patch is here
patch < genericio-add-install-rules.patch
mkdir build && cd build && ccmake .. && make install
All that is left to do is to set the GenericIO_DIR to where you installed genericio and recompile ParaView.
hint
And alternative is to use the superbuild if you can.
