How to access RenderView name in pvpython
Hi all,
using pvpython, how do you access the custom name given to a view, e.g. a RenderView.
In the shown snapshot, the layout was manually renamed to “MyLayout” and the view was renamed to “MyView”. With the following script, I would like to access the view name, here “MyView”.
from paraview.simple import *
layouts = GetLayouts()
for i,l in enumerate(layouts):
    print("Layout name:", l[0]) # This prints "MyLayout"
    views = GetViewsInLayout(layouts[l])
    for j,v in enumerate(views):
        print("View name:", v.SMProxy.GetName()) # I want this to print "MyView"
This fails as there is no method GetName(), but using GetLogName() only returns “RenderView1”, etc. Is there a way to access the name shown in the GUI similar to the layout name?
Thank you in advance!
Regards,
mckel
Based on this discussion, the following code using servermanager.ProxyManager().GetProxyName(...) function can be used:
        print("View name:", servermanager.ProxyManager().GetProxyName(v.SMProxy.GetXMLGroup(),v)) # This prints "MyView"
