I would like to develop a plugin based on VTKPythonAlgorithmBase.
This plugin take as input a vtkDataset and 3 coordinates representing the position of a camera.
With the following code, I’ve managed to expose these 3 coordinates in Paraview’s properties panel:
@smproperty.doublevector(name="Camera", default_values=[1, 1, 1], label="Camera")
@smdomain.doublerange()
def Set1_Camera(self, x, y, z):
value = np.r_[x, y, z]
if not np.allclose(self._camera, value) :
self._camera = value
self.Modified()
I also succeed in adding a button which prints the position of the camera in the output window:
@smproperty.xml('''<Property name="Print Camera Position" command="CameraButton" panel_widget="command_button"></Property>''')
def CameraButton(self, *args):
import paraview.simple
camera = paraview.simple.GetActiveCamera()
print('Camera position : ', camera.GetPosition())
Instead of printing the camera position in the output window, I would like to fill the properties panel with these values.
How can I access to theses properties from the CameraButton function ?
This is incorrect! One should not access paraview.simple module in the algorithms like so. I won’t go into details, but this is a big no-no in client-server configurations.
There’s no way to support this the way you’re implementing. The only reasonable solution would be add a custom property widget for the SetCamera property that then uses a custom pqPropertyWidget subclass that can access the active view and camera from the client side and then set the value to it. That will require C++ code, however, and cannot be done simply in VTKPythonAlgorithmBase subclass.
Could someone explain to me the reason? I develop Python algorithms (subclassing VTKPythonAlgorithmBase) that partially rely on paraview.simple. I faced one problem only (although I haven’t tested it in client-server mode yet): using Show in RequestInformation or RequestData leads to infinite recursion. On the other hand, I can use Show from a separate method, e.g. a method decorated with an XML property that creates a push button in the Properties panel. So which functions should we avoid using in a Python plugin? After a discussion with Kitware, I learnt that it is better that a Python algorithm only deals with the data management, not the GUI functionalities. But I would like to understand why this is the case.
Thank you. So it means that I should separate the functionalities into two: one VTKPythonAlgorithmBase-based plugin that does not rely on the client and a Python script that does the automations in the ParaView GUI.
