How to access to OPS SCALE FUNCTION
I am in the process of making a simulation by Paraview, which will require OPS SCALE FUNCTION. I have installed different versions of the software. However, I failed to find it.
Please tell me how to access this feature?
Best regards
@timothee.chabat
This doesn’t look like the property editor I know, what version are you using ?
For ParaView 5.9 and 5.10, activate the advanced option and go to section Display Properties -> Ray Tracing -> Scaling Mode. If you choose the Each Scaled mode, you’ll be able to edit the scale function and select the data array used for the scaling.
See OSPRay scaling points - #6 by Michael for a similar discussion around this feature.
thanks a lot for your help
