How to calculate sum of variable and move to global data
Hi everyone,
I have a user that is trying to do calculations on point (or cell) data, and then move the result into a global variable. For instance, the user wants to do the following:
# Code for ‘Script’
# ‘inputs’ is set to an array with data objects produced by inputs to
# this filter.
# Get the first input.
input0 = inputs[0]
# compute a value.
dataArray = sum(input0.PointData[“V”])
# ‘output’ is a variable set to the output dataset.
output.FieldData.append(dataArray, “V_sum”)
Any idea how do do this?
Thanks, Alan
I dont see anything wrong with that code. At first glance, it should work.
Obviously, code is from user. Let me try it.
