Hi Paraview community,
In the file, I want to change the AxisOfSymmetry from 1 to 2, can anyone suggest an easy way to change it in Paraview? Thanks!
vtkSuperquadricSource::vtkSuperquadricSource(int res)
res = res < 4 ? 4 : res;
Thanks Mathieu! I have looked at the method you suggested. While it seems a little difficult for me to understand the code. Do you have any other example/document for me to learn how to write the plugin? I am using paraview 5.6, I hope to do it in the GUI.
Thanks Mathieu for your help. I can successfully load the file your provided, while I could not see it. (I tested other examples, they can be seen.)
One more question, since I need to use TensorGlyph ( in TensorGlyph—>select superquadric), how to make this change (AxisOfSymmetry=2) also works for TensorGlyph?
Once again, you need to do that in the xml plugin and point to your new superquadric source
