How to change the index of the first point for plotting
I have the following set of vertex cells as shown in the screenshot below:
These vertex cells are ordered counter-clockwise as indicated (notice the cells with index 0, 1, … 13, … etc).
When I use the “Plot Data” Filter and checking the option “Use Index for X Axis” (as shown below):
I want to shift the index of the points: So for example: I want the point with index 13 (shown in the first screenshot above) to be the point with index 0, Index 14 to be index 1, and so on. As a result, the plot will be shifted horizontally.
How to achieve that in ParaView?
I appreciate your help.
Thank you
you need to compute this shifted index. I think the simplest way would probably be by using a programmable filter to compute it.
How?
https://docs.paraview.org/en/latest/ReferenceManual/pythonProgrammableFilter.html
I tried with this:
data = inputs[0]
# Get the number of points in the dataset
numPoints = data.GetNumberOfPoints()
# Create a new vtkPoints container for the rotated order
newPoints = vtk.vtkPoints()
newPoints.SetNumberOfPoints(numPoints)
offset = 13
for i in range(numPoints):
    # Compute the original index for the new index i
    originalIndex = (i + offset) % numPoints
    pt = data.GetPoint(originalIndex)
    newPoints.SetPoint(i, pt)
# Copy the input to the output so that other data (like cell data) is preserved
output.ShallowCopy(data)
# Replace the points in the output with the newly ordered points
output.SetPoints(newPoints)
But I get this error:
  File "<string>", line 22, in <module>
  File "<string>", line 15, in RequestData
  File "C:\Program Files\ParaView 5.13.2\bin\Lib\site-packages\vtkmodules\numpy_interface\dataset_adapter.py", line 128, in __getattr__
    return getattr(self.VTKObject, name)
AttributeError: 'vtkmodules.vtkCommonDataModel.vtkMultiBlockDataSet' object has no attribute 'GetPoint'
