I made finally some progress, since on Ubuntu libglvnd is used, I needed to force nvidia vendor.
DISPLAY=:0 _GLX_VENDOR_LIBRARY_NAME=nvidia glxgears
name of display: :0
display: :0 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_profile, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multisample_coverage, GLX_NV_present_video,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_NV_video_capture, GLX_NV_video_out, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer
OpenGL vendor string:
OpenGL renderer string:
OpenGL version string:
OpenGL extensions:
The problem is now that, when I run pvserver, I get:
DISPLAY=:0 __GLX_VENDOR_LIBRARY_NAME=nvidia pvserver
Waiting for client...
Connection URL: cs://hostname:11111
Accepting connection(s): hostname:11111
Client connected.
ERROR: In /dev/shm/ruben/spack-stage-paraview-5.6.3-gwc3rrsjqd2koa4rtl3gjiaqzprgr4vq/spack-src/VTK/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 736
vtkXOpenGLRenderWindow (0x5613694ab070): GLEW could not be initialized.
ERROR: In /dev/shm/ruben/spack-stage-paraview-5.6.3-gwc3rrsjqd2koa4rtl3gjiaqzprgr4vq/spack-src/VTK/Rendering/OpenGL2/vtkXOpenGLRenderWindow.cxx, line 796
vtkXOpenGLRenderWindow (0x5613694ab070): failed to create offscreen window
Any idea why?
