GenerateIds should do the trick
Thank you, but I’m referring to the Block Number, not the point ID.
Indeed, the to use filter is named “BlockIds”
I can’t find this filter “Block ids”
Which version of ParaView are you using ?
pv 5.6
This filter probably does not exists with ParaView v5.6, please update to the latest release, you can find it here: https://www.paraview.org/download/
ok, I’ll try, thank you.
