Is it possible within Paraview to create a moving dataset that follows a moving object?
A little bit of context:
I need to post-process a flow simulation around a moving airfoil. I have to use a dataset (such as an ellipse surrounding the airfoil) to sample data on it. While this is straightforward for a static mesh, I am curious if it is possible to have the dataset (in this case, the ellipse) move with the airfoil in its motion.
Create the sampling dataset manually using Python for every timestep and save it as CSV files.
Load the CSV files, and apply the “Tables to points” filter. Then add a calculator filter to generate the coordinates vector of the dataset explicitly.
Export the data as .pvd data for all time steps.
Manually modify the .pvd file using GNU sed to use the correct timesteps (the same timesteps of the target simulation).
Load the simulation.
Load the .pvd file.
The dataset should follow the target object from the simulation.
