I tried to interpolate my dataset but after interpolating it, some dataset resulted in NaN values.
In order to discard the dataset, I need to make a ’ if ’ conditional part to save only real numbers.
From the resulted spread sheet, the name of the column having NaN values is ‘pressure’.
I thought I can write the code like this below, but it did not work at all…
# save data
if np.isnan(interp_model['pressure']) == False:
SaveData(os.path.join(tar_dir_new, filename), proxy=interp_model, PointDataArrays=data_array)
My Python script for interpolation looks like this.
# Loop through different reduction rates
for rate in reduction_rates:
print(f"reduction rate = {rate:.1f}")
# Define target directory for each reduction rate
tar_dir_new = os.path.join(tar_dir, f"reduction_rate={rate:.1f}")
if not os.path.exists(tar_dir_new):
os.makedirs(tar_dir_new)
# Load target grid
# Assumes reduced mesh is saved in ".vtk" format and that is the only ".vtk" file in the directory
reduced_path = os.path.join(tar_dir_new, [n for n in os.listdir(tar_dir_new) if ".vtk" in n][0])
reduced_model = LegacyVTKReader(
registrationName=os.path.basename(reduced_path),
FileNames=[reduced_path]
UpdatePipeline(time=0.0, proxy=reduced_model)
# Loop through src directory
for root, dirs, files in os.walk(src_dir):
# Finds files ending with ".vtp" and assume they are original data
file_to_look = [n for n in files if ".vtp" in n]
for n, filename in enumerate(file_to_look):
print(f"\t{n + 1} / {len(file_to_look)}: ")
src_path = os.path.join(root, filename)
# Read source file
src_model = XMLPolyDataReader(
registrationName=os.path.basename(src_path),
FileName=[src_path]
src_model.PointArrayStatus = data_array
src_model.TimeArray = 'None'
UpdatePipeline(time=0.0, proxy=src_model)
# create a new 'Point Dataset Interpolator'
interp_model = PointDatasetInterpolator(
registrationName='PointDatasetInterpolator1',
Input=src_model,
Source=reduced_model
interp_model.Kernel = 'VoronoiKernel'
interp_model.Locator = 'Static Point Locator'
UpdatePipeline(time=0.0, proxy=interp_model)
# save data
ResetSession()
How can I skip saving interpolated dataset that has NaN values?
Thanks!
