How to extract data form PlotDataOverTime filer with python/pvpython
Hello all,
I’m writing a pvpython script to evaluate the mean flow over a surface for every time step, and do some further calculation with the extracted data.
As a first approach, i applied the integrate variables filter (iv) and used a for loop to cycle over times steps in order to extract the data using the servermanager.Fetch(iv) method.
Here a summary of what I do, just to get an idea.
iv= IntegrateVariables(Input=sda) # sda is the surface
iv.UpdatePipeline()
iv_data= servermanager.Fetch(iv)
for t in timesteps:
  iv.UpdatePipeline(time=t) # update pipline at t
  data_iv = servermanager.Fetch(iv)
  flow_temp = data_iv .GetRowData().GetArray("velocity")
  flow_data[surf_id] = vnp.vtk_to_numpy(flow_temp )
However, fetching data every time is not the smarter way, I think.
Thus, I figured out I can use the PlotDataOverTime filter to avoid this.
However, i cannot find a way to access to the “Row Data” of the filter.
Can you explain me how to do this?
Here a small part of my code to attempt on figuring what type of attributes the PlotDataOverTime filter had:
dataotime = PlotDataOverTime(Input=iv)
pdataotime.UpdatePipeline()
data_pdataotime = servermanager.Fetch(pdataotime)
print(“RowData plot over time:”, data_pdataotime.GetData.keys())
I know that I can export the data to a csv and then read the csv inside the script, but for me does not make sense that i cannot acces to the data directly using the PlotDataOverTime object itself.
Moreover, I found that using
PlotDataOverTime(Input=sda)
directly on the surface provides sometimes similar results with respect to
iv.UpdatePipeline()
Why? Is it because PlotDataOverTime evaluate the average over the surface?
Thanks in advance, any help would be highly appreciated.
Cheers!
Do not do that, instead write a programmable filter that will do the processing on the server side.
