How to get into visualize webpage
Hello:
I installed paraview in my ubuntu server for running visualizer, I can access the page in ubuntu by
“http://localhost:9090”(the port is 9090)
however, it comes with
ERR_CONNECTION_TIMED_OUT
when I tried to access the URL by browser in windows
How to deal with this :frowning:
When running the process, add that extra argument --host 0.0.0.0 to allow external connection.
Hello, I tried but did not work;
my 8080 port is occupied, and I tried:
--pvpython -m paraview.apps.visualizer --data /mydata --host 0.0.0.0 --port 9090
Then I access through browser (on windows) by host:9090, and it comes with
How to solve this?Thanks
Without more information, it is hard to say. I don’t know your network setup, your firewall rules and so on. I don’t even know if your Windows can ping your Linux. Or even what URL you are truly using in your windows browser. Do you use localhost, host or the actual IP of your linux box?
I used IP of my linux box
with in same net work
I can access the port 8080 on web(windows) however can not access any port which is provided by paraview visualizer, weriod
What does your browser debug view tells you (console and network)?
When your other 8080 service is not running does visualizer on 8080 works?
luckly, when I turned paraviews’ port to 8080, it worked, however, with nothing on the webpage:
I solved~ thanks so much!
Can you provide some hints on what was the issue so other can learn from your experience?
of course, the main part is to add --host 0.0.0.0, besides, release the port which paraview visualizer will occupy
it was my mistake of not realizing the 9090 port was not allowed to access
Thanks for the feedback.
