I am having difficulty getting the names of the selected blocks using this call. First, I select some subset of blocks, then I call Extract Selection. However, I can’t seem to get the block names out.
If I look at the hierarchy inside the extracted selection via the mutli-block inspector, all the original block names are present (i.e., both selected blocks and unselected ones). In the UI, the selected blocks are available:
Any tips about how to get the selected block names in python would be appreciated.
I am still confused. I created a simple example where I create two point sources (offset from each other), Group them into a multi-block, the select one of the two blocks, and call extract selection. In the extract selection object, I can still call
