How to get selection for plot s. over Time of descriptive Statistics Filter?
Hey there,
I fail at making a working selection via script.
How can I determine what to write at Selection=
plotSelectionOverTime1 = PlotSelectionOverTime(Input=descriptiveStatistics1,
Selection=None)
Error msg is this: Warning: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.6.0/ParaViewCore/VTKExtensions/Default/vtkSciVizStatistics.cxx, line 581
vtkPSciVizDescriptiveStats (0x55e5205a2ed0): Every requested array wasn’t a scalar or wasn’t present.
The code I got via the Trace function.
Regards,
Terry
Tracing does not work with selection (yet). You have to create the selection manually in your script first.
Use something like :
selection = SelectCells("id <= 35")
Selection=selection)
Thank you for your very fast reply!
How can I determine an ID for a filter output that does not show in RenderView?
the “id <= 35” is just a dummy formula. How do you select your cells or points usually ?
Usually I use something like:
for i in range(2):
selection = SelectCells(query=“id==” +str(i))
plotSelectionOverTime = PlotSelectionOverTime(Input=contour1, Selection=selection)
However I can’t find a way to determine to select something after using the descriptiveStatistics filter via paraviev.simple as it does not “create a cell to select” like many other filters do.
Maybe I have to go the other way around:
Instead of: select --> plot selection over time
I could try: SaveData with proxy descriptiveStatistics and WriteTimeSteps=1. And write me something to get the data out of all these files and into one I could use with gnuplot…
Right, you want to select rows in a table, i missed that.
There is no SelectRows (yet), but you can do it manually with the following code:
selSource = servermanager.sources.SelectionQuerySource()
selSource.FieldType = "ROW"
selSource.QueryString = "id == 2"
descriptiveStatistics.SMProxy.SetSelectionInput(descriptiveStatistics.Port, selSource.SMProxy, 0)
be aware that the Spreadsheet view does not update itself with these manual selections, so you will have to create a new one to see it.
Thank you so much, I will try that right now. :slight_smile:
If I’m correct the selection is working now with your code.
However I am still not able to use the filter via python
This is the TraceBack:
create a new ‘OpenFOAMReader’
create a new ‘Descriptive Statistics’
File “volumenschwerpunkt.py”, line 39, in
descriptiveStatistics1.AttributeMode = ‘Point Data’
File “/opt/paraviewopenfoam56/lib/python2.7/site-packages/paraview/servermanager.py”, line 471, in setattr
raise ValueError("%s is not a valid value for attribute s." (value, name))
ValueError: Point Data is not a valid value for attribute AttributeMode.
‘Field Data’ is accepted instead of ‘Point Data’ but empty.
Works fine here, could you send a minimal example reproducing the error ?
While making the minimal example I had an Idea and it works now:
Before from the trace:
descriptiveStatistics2 = DescriptiveStatistics(Input=calculator2,
ModelInput=None)
descriptiveStatistics2.AttributeMode = ‘Point Data’
descriptiveStatistics2.VariablesofInterest = [‘U’, ‘alpha.water’, ‘p_rgh’, ‘postion’]
descriptiveStatistics2.Task = 0
descriptiveStatistics2.TrainingFraction = 0.1
descriptiveStatistics2.Deviationsshouldbe = 0
Now Working:
print “create a new ‘Descriptive Statistics’”
descriptiveStatistics1 = DescriptiveStatistics(Input=calculator1, ModelInput=None)
descriptiveStatistics1.AttributeMode = 0
descriptiveStatistics1.VariablesofInterest = [‘U’, ‘alpha.water’, ‘p_rgh’, ‘position’]
descriptiveStatistics1.Task = 0
descriptiveStatistics1.TrainingFraction = 0.1
descriptiveStatistics1.Deviationsshouldbe = 0
Thank you very much for your help!
Great. FYI, on ParaView 5.7, enum in Python should work.
