How to import a series of files with Programmable Source
How to import a series of files with Programmable Source, the attachment is the import code for a single file
import numpy as np
import struct
try:
with open(r’c:\00yf\dh2\bin2-time0.raw’, “rb”) as f:
contents = f.read()
    bytesnum = int((len(contents) - 4)/3)    # 某一个分量占的字节总数,其中减去的4个为换行符
    realnum = int(bytesnum/4)   #某一分量的个数
    numlist = []
    i = 0
    while True:
        if (i+4) <= len(contents):
            bytetoascii = struct.unpack('f', contents[i:i+4])
            bytetoasciishort = round(bytetoascii[0], 3)
            numlist.append(bytetoasciishort)
            i += 4
            if (i == bytesnum):
                i = bytesnum + 2
            elif (i == bytesnum*2 + 2):
                i = bytesnum*2 + 4
        else:
            break
x = np.array(numlist[:realnum])
y = np.array(numlist[realnum:realnum*2])
z = np.array(numlist[realnum*2:])
except IOError:
print(“Error While opening the file!”)
data = np.genfromtxt(r’D:\test\PointCloud\temp.txt’, dtype=None, names = None, delimiter=‘,’, unpack = False)
#output.RowData.append(data[:,0] , ‘x’)
#output.RowData.append(data[:,1] , ‘y’)
#output.RowData.append(data[:,2] , ‘z’)
output.RowData.append(x , ‘x’)
output.RowData.append(y , ‘y’)
output.RowData.append(z , ‘z’)
