Hi, thanks for your answer!
I searched the PYTHONPATH variable and it was inexistent, so, I created a new one pointing to:
C:\Program Files\ParaView 5.4.1-Qt5-OpenGL2-Windows-64bit\bin
And now PIP is recognized, but when I execute:
pip install opencv-python
I have this message:
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
Requirement already satisfied: opencv-python in c:\python27\lib\site-packages (2.4.11)
Does this mean that I can no longer install opencv in this Python version?
I also tried to change PYTHONPATH to the path mentioned in the message (it is a Python2.7 already installed in my computer that I use it with the PythonXY software). Inside this folder I can see the numpy and openCV folders.
However, when I go back to pvpython and I try to load numpy it gives an error (shown below). The same happens with opencv (Also the Python Shell fails to load numpy).
This is because the Python version used in Paraview is 2.7.3 instead of 2.7? (It should be the same thing right?)
Hopefully I can avoid the numpy error if I change PYTHONPATH back to the Python of Paraview, i.e.:
But I’m still without openCV…
Any sugestions? Thanks in advance!
Miguel
PS: is there any PV release with opencv included? If not, it could be interesting to consider that because it allows users to exploit Paraview as a platform for Augmented Reality projects without facing the painful processs of installing this classic package.
MESSAGE ERROR:
File “”, line 1, in
File “C:\Python27\Lib\site-packages\numpy_init_.py”, line 170, in
from . import add_newdocs
File “C:\Python27\Lib\site-packages\numpy\add_newdocs.py”, line 13, in
from numpy.lib import add_newdoc
File “C:\Python27\Lib\site-packages\numpy\lib_init_.py”, line 8, in
from .type_check import *
File “C:\Python27\Lib\site-packages\numpy\lib\type_check.py”, line 11, in
import numpy.core.numeric as _nx
File “C:\Python27\Lib\site-packages\numpy\core_init_.py”, line 6, in
from . import multiarray
ImportError: DLL load failed: %1 nÆest pas une application Win32 valide.
