I am Sahel, a new user of Paraview. Recently, I am trying to install Paraview 5.8 in my personal home directory of the DELL visualization server machine. I have downloaded the tar file and tried to install it. As I am not super user, I can’t softlink
ParaView-5.8.0-MPI-Linux-Python3.7-64bit/bin/paraview to /usr/bin/paraview &
ParaView-5.8.0-MPI-Linux-Python3.7-64bit//lib/paraview-5.8/ to /usr/lib/paraview-5.8
to invoke paraview from terminal. Is it possible to install it this way to use remotely?
Paraview 5.0 is already installed there for all users with required dependencies but for some reason, the graphical interface is getting hanged every time. Therefore, I am trying to install it in my home space.
It would be helpful if you can give me some suggestions to resolve this issue.
Yes, you can definitely untar the file you downloaded in any directory in which you have access and run it from there, unless for some reason your system disallows running executables from arbitrary directories. Either give the full path to the executable you want to run, or add that directory to your PATH environment variable.
Thanks a lot Cory for your reply. I was trying to set path for invoking Paraview. After setting path, again I am getting some errors. Can you please check it ?
Since ParaView 5.0 is already installed, I assume that means it is officially supported by your organization. I suggest you contact the system administrators for technical help on getting either 5.0 or 5.8 working.
