I have created a plugin for PV that creates unstructured grid. But to load the generated grid I need to drug and drop it into PV.
(Current version of my plugin has front end in ParaView, I mean buttons and textLines, but back end (generation of unstructured grid) is a simple c++ code, that does not interact with ParaView classes for now).
So next step I need to write a code that will automatically load and show the grid in ParaView.
But I don’t know how to interact with ParaView classes using C++.
Can you show me at least some basic functionality, for example how to change background color or how to Render a cone from sources. And if you have a good manual, please share.
I need to know the libraries I should import, and objects I can use.
Thank you Mathieu for your reply.
I checked this link, but it mainly describes how to write plugins using xml.
I understood that it is a preferred way of writing plugins, and I will try to understand its logic later.
But for now I wanted to use C++ API to write the plugin.
I found functions to load a grid:
I don’t need much to do at server side.
I need only to load and reload a grid (And I found how to do it),
Check if a file is open, change its representation and apply after loading.
To change the representation I tried to use:
vtkSMPropertyHelper(file->getProxy(), “Representation”).Set(“Wireframe”);
but it does not work.
If it is possible, can you tell me how to do that?
