I’m trying to load an e57 file in LidarView and I can’t figure out which reader to use. I’ve tried a couple of them, like the default AVS UCD Reader: I don’t get any errors but I can’t see anything loaded.
This should be readable by the pdal reader but a quick try with ParaView doesnt seem to work, please open an issue (in ParaView).
Thanks, here’s a link to the new topic: Opening e57 files using the pdal reader - ParaView Support - ParaView
Hi @rowan , if you have a local build you should enable Xerces in the build. When I do, BunnyDouble.e57 file from E57 Data Examples loads correctly with the PDAL reader.
We should probably consider include this in the binaries
I’ve got a build compiled with both PDAL and xerces superbuild options and now I’m getting these errors when I try to load my e57 file:
ERROR: In vtkPDALReader.cxx, line 87
vtkPDALReader (00000131E20D6BC0): Cannot open file C:\Users\raw17\Downloads\bunnyDouble.e57
ERROR: In vtkExecutive.cxx, line 730
vtkPVCompositeDataPipeline (00000131E25EFEC0): Algorithm vtkPDALReader (00000131E20D6BC0) returned failure for request: vtkInformation (00000131E2CDA420)
Debug: Off
Modified Time: 1587610
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
Solution was posted in this thread:
OpenXR errors when using XRInterface in Lidarview - VR/AR - ParaView
