Dear more experienced and knowledgeable friend,
I have run a model in openFoam, and used foamToVTK to generate vtm files (somehow it did not generate a vtk file).
I wish to postprocess this model automatically (as in reality there are hundreds of these runs that I prefer not to do by hand).
Post processing involves computing the streamtracers and computing some of their properties
To do this, I have ran a trace in the ParaView GUI (started with paraFoam) and done this my hand.
The trace gave me the following script:
from paraview.simple import *
porousFlowfoam = GetActiveSource()
streamTracer1 = StreamTracer(registrationName='StreamTracer1',
Input=porousFlowfoam,
SeedType='Line')
and then it proceeds with setting up the member variables of streamTracer1.
When I run this script on its own from the shell (as opposed to in the GUI), I get a:
( 2.005s) [paraview ]vtkDemandDrivenPipeline:675 ERR| vtkPVCompositeDataPipeline (0xfa50b0): Input port 0 of algorithm vtkPStreamTracer (0xeb17f0) has 0 connections but is not optional.
which I suppose makes sense, because in the shell there is no data loaded, so no active source… I guess?
I followed documentation and replaced the GetActiveSource() command by
porousFlowfoam = LegacyVTKReader(FileNames=['VTK/meshMaker_2.vtm'])
That vtm file contains links to the data I need. Reading this vtm gives me:
( 2.433s) [paraview ] vtkPDataSetReader.cxx:134 ERR| vtkPDataSetReader (0xeb6630): This does not look like a VTK file: VTK/meshMaker_2.vtm
( 2.436s) [paraview ] vtkPDataSetReader.cxx:170 ERR| vtkPDataSetReader (0xeb6630): Unknown data type.
( 2.436s) [paraview ] vtkExecutive.cxx:729 ERR| vtkPVCompositeDataPipeline (0xf056d0): Algorithm vtkFileSeriesReader (0xf037a0) returned failure for request: vtkInformation (0xf04f70)
Debug: Off
Modified Time: 95518
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA_OBJECT
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
Am I bamboozled by the subtle differences between vtk and vtm files?
Is there somewhere documentation that I missed, explaining how to let a pvpython script read in output of foamToVTK?
Thanks a lot,
Lukas
