maruthinh
(Maruthi NH)
1
# import the simple module from the paraview
from paraview.simple import *
import numpy as np
for i in range(102, 276, 2):
# disable automatic camera reset on 'Show'
#paraview.simple._DisableFirstRenderCameraReset()
# create a new 'CSV Reader'
payload_surfcsv = CSVReader(
FileName=['./3d_surf_data/surface_data_'+str(i)+'.csv'])
#payload_surfcsv = CSVReader(FileName=['/mnt/external_data/maruthi/payload/to_surf_data.csv'])
#payload_surfcsv = CSVReader(FileName=['/mnt/external_data/maruthi/payload/payload_surf.csv'])
print("read data")
# Properties modified on payload_surfcsv
payload_surfcsv.HaveHeaders = 0
payload_surfcsv.FieldDelimiterCharacters = '" "'
# create a new 'Table To Points'
tableToPoints1 = TableToPoints(Input=payload_surfcsv)
# Properties modified on tableToPoints1
tableToPoints1.XColumn = 'Field 0'
tableToPoints1.YColumn = 'Field 1'
tableToPoints1.ZColumn = 'Field 2'
# set active source
# SetActiveSource(tableToPoints1)
# create a new 'Transform'
transform1 = Transform(Input=tableToPoints1)
# Properties modified on transform1.Transform
transform1.Transform.Rotate = [0.0, 0.0, 4.0]
print("done transformation")
# create a new 'Clip'
clip1 = Clip(Input=transform1)
clip1.ClipType = 'Box'
# Properties modified on clip1.ClipType
clip1.ClipType.Position = [-1.696043450844211, -54.8910389148131, -0.33203125]
clip1.ClipType.Length = [471.2158891012069, 109.7879512755795, 0.33203125]
#print("position", clip1.ClipType.Position)
#clip1.ClipType.Position[2] = -0.33203125
#clip1.ClipType.Length[2] = 0.33203125
clip2 = Clip(Input=clip1)
# Properties modified on clip2.ClipType
clip2.ClipType.Normal = [0.0, -1.0, 0.0]
print("clip2 done")
# save data
# SaveData('/mnt/external_data/maruthi/payload/clipped_surf_data_hello.csv',
# proxy=clip2, PointDataArrays=['Field 3', 'Field 4'])
SaveData('clipped_data/clipped_surf_data_'+str(i)+'.csv',
proxy=clip2)
