Hello everyone!
I have two contours now and I have plotted the isolines of them.
I want to mark the values on the isolines, but I found if I use the “Interactive Select Points On” feature to mark the value in contour A, the values in A would disappear if I do the same in contour B.
So is there any means to keep the values visible both in the two contours in the meanwhile?
Thanks for your help in advance.
Try to create an Annotate Attribute Data filter. Note that you may switch positioning to 3D space instead of default screen space.
