Does anyone know of a script to merge multiple PVD and VTP files? I’m talking 100s of…not 2 or 3.
Question details below…
Looking at one of the VTP files, by typing on the command line:
more PART_00000.vtp
I get the following output…
<?xml version='1.0'?>
<VTKFile type='PolyData' version='0.1' byte_order='LittleEndian'>
<PolyData>
<Piece NumberOfPoints='2221680' NumberOfVerts='2221680'>
<Points>
<DataArray type='Float64' Name='Position' NumberOfComponents='3' format='appended' offset='0'/>
</Points>
<PointData Scalars='Pressure' Vectors='Velocity'>
<DataArray type='Float32' Name='Pressure' format='appended' offset='53320324'/>
<DataArray type='Float32' Name='Velocity' NumberOfComponents='3' format='appended' offset='62207048'/>
<DataArray type='Float32' Name='Density' format='appended' offset='88867212'/>
<DataArray type='Float32' Name='Mass' format='appended' offset='97753936'/>
<DataArray type='Float32' Name='SPS turbulent viscosity' format='appended' offset='106640660'/>
<DataArray type='UInt8' Name='Part type' format='appended' offset='115527384'/>
<DataArray type='UInt8' Name='Part flags' format='appended' offset='117749068'/>
<DataArray type='UInt8' Name='Part object' format='appended' offset='119970752'/>
<DataArray type='UInt32' Name='Part id' format='appended' offset='122192436'/>
<DataArray type='UInt32' Name='CellIndex' format='appended' offset='131079160'/>
</PointData>
<Verts>
<DataArray type='UInt32' Name='connectivity' format='appended' offset='139965884'/>
<DataArray type='UInt32' Name='offsets' format='appended' offset='148852608'/>
</Verts>
</Piece>
</PolyData>
<AppendedData encoding='raw'>
followed by a bunch of binary/encoded stuff. I have a whole bunch of these types of files which can be found listed in a ParaView Data file (.pvd format) by executing the following from the command line
more VTUinp.pvd
which gives
<VTKFile type='Collection' version='0.1'>
<Collection>
<DataSet timestep='0' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0' group='1' name='WaveGages' file='WaveGage_00000.vtu'/>
<DataSet timestep='0' group='2' name='Particles' file='PART_00000.vtp'/>
<DataSet timestep='0.1000990719476249' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.1000990719476249' group='1' name='WaveGages' file='WaveGage_00001.vtu'/>
<DataSet timestep='0.1000990719476249' group='2' name='Particles' file='PART_00001.vtp'/>
<DataSet timestep='0.2000853080899105' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.2000853080899105' group='1' name='WaveGages' file='WaveGage_00002.vtu'/>
<DataSet timestep='0.2000853080899105' group='2' name='Particles' file='PART_00002.vtp'/>
<DataSet timestep='0.3000886073423317' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.3000886073423317' group='1' name='WaveGages' file='WaveGage_00003.vtu'/>
<DataSet timestep='0.3000886073423317' group='2' name='Particles' file='PART_00003.vtp'/>
<DataSet timestep='0.4000112119101686' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.4000112119101686' group='1' name='WaveGages' file='WaveGage_00004.vtu'/>
<DataSet timestep='0.4000112119101686' group='2' name='Particles' file='PART_00004.vtp'/>
<DataSet timestep='0.5000988173051155' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.5000988173051155' group='1' name='WaveGages' file='WaveGage_00005.vtu'/>
<DataSet timestep='0.5000988173051155' group='2' name='Particles' file='PART_00005.vtp'/>
<DataSet timestep='0.6000160886978847' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.6000160886978847' group='1' name='WaveGages' file='WaveGage_00006.vtu'/>
<DataSet timestep='0.6000160886978847' group='2' name='Particles' file='PART_00006.vtp'/>
<DataSet timestep='0.700017443698016' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.700017443698016' group='1' name='WaveGages' file='WaveGage_00007.vtu'/>
<DataSet timestep='0.700017443698016' group='2' name='Particles' file='PART_00007.vtp'/>
<DataSet timestep='0.8000870649775607' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.8000870649775607' group='1' name='WaveGages' file='WaveGage_00008.vtu'/>
<DataSet timestep='0.8000870649775607' group='2' name='Particles' file='PART_00008.vtp'/>
<DataSet timestep='0.9000359851925168' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='0.9000359851925168' group='1' name='WaveGages' file='WaveGage_00009.vtu'/>
<DataSet timestep='0.9000359851925168' group='2' name='Particles' file='PART_00009.vtp'/>
<DataSet timestep='1.000061886152253' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.000061886152253' group='1' name='WaveGages' file='WaveGage_00010.vtu'/>
<DataSet timestep='1.000061886152253' group='2' name='Particles' file='PART_00010.vtp'/>
<DataSet timestep='1.100044853170402' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.100044853170402' group='1' name='WaveGages' file='WaveGage_00011.vtu'/>
<DataSet timestep='1.100044853170402' group='2' name='Particles' file='PART_00011.vtp'/>
<DataSet timestep='1.200035295594716' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.200035295594716' group='1' name='WaveGages' file='WaveGage_00012.vtu'/>
<DataSet timestep='1.200035295594716' group='2' name='Particles' file='PART_00012.vtp'/>
<DataSet timestep='1.300029617945256' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.300029617945256' group='1' name='WaveGages' file='WaveGage_00013.vtu'/>
<DataSet timestep='1.300029617945256' group='2' name='Particles' file='PART_00013.vtp'/>
<DataSet timestep='1.400022054469446' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.400022054469446' group='1' name='WaveGages' file='WaveGage_00014.vtu'/>
<DataSet timestep='1.400022054469446' group='2' name='Particles' file='PART_00014.vtp'/>
<DataSet timestep='1.500012752476323' group='0' name='Topography' file='DEM.vts'/>
<DataSet timestep='1.500012752476323' group='1' name='WaveGages' file='WaveGage_00015.vtu'/>
<DataSet timestep='1.500012752476323' group='2' name='Particles' file='PART_00015.vtp'/>
</Collection>
</VTKFile>
In Paraview, when I go to open a single group of files it gives me the option to open Part_…vtp which opens all the files contained in that directory (those listed in the .pvd file above) and I can step through them without a problem. Great!
My problem is that the program that creates these files sometimes needs to perform a “resume/restart/hotstart”. When this happens, a new output directory is created, so I have several directories containing 1) Many Part*.vtp files 2) Corresponding VTUinp.pvd 3) Plus bunch of other files. The restart of the filename indexing isn’t really a problem, because the ParaView Data file thankfully tracks the time step. However, I want to open the full time series (all “resume/restart/hotstart” files) in ParaView, but I don’t know how to do this. Ideally I would like to merge the necessary data files with a script before even trying to open in ParaView. I think there is a “GroupData” filter, but I have 100s of folders and it will take forever to do that by hand (not to mention doing it more than once).
Can someone tell me if such a script exists? If not, can someone give me some insight on how I would do this?
