I have some simulations done with openfoam and have some wind tunnel data, where I have the vertical and streamline velocity. I would like to compare this two with a image including the velocity magnitude contour and streamlines. As I am writing a follow up thesis I would like to do this in the similar manner as my predecessor. I would like to achieve a images such as this:
I am unable so far to generate the streamline on a 2D plot so far. I think there is a python option streamslice, which should enable this. I however do not understand how I can apply this, even after quite a research… Could you give you explain to my the workflow for this?
I also would like to have the same horizontal length scales with x/H and y/H. How can I achieve this?
Sorry if this questions is to simply but I am quite stuck right now.
Hi thanks for the quick reply. I tried but I get the following error:
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Filters\FlowPaths\vtkEvenlySpacedStreamlines2D.cxx, line 125
vtkEvenlySpacedStreamlines2D (0000017C53E8E7A0): vtkEvenlySpacedStreamlines2D does not support planes not aligned with XY.
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (0000017B05A8AEB0): Algorithm vtkEvenlySpacedStreamlines2D(0000017C53E8E7A0) returned failure for request: vtkInformation (0000017BA0016140)
Debug: Off
Modified Time: 29153292
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
Respective if I use it on z-plane:
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753 vtkCompositeDataPipeline (0000017AB5754D50): Algorithm vtkPVGeometryFilter(0000017BA0098320) returned failure for request: vtkInformation (0000017AE9B67870) Debug: Off Modified Time: 50048809 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA_OBJECT FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 FROM_OUTPUT_PORT: 0
My workflow for is so far:
-slice vertical or horizontal plane
