Hi thanks for the quick reply. I tried but I get the following error:
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Filters\FlowPaths\vtkEvenlySpacedStreamlines2D.cxx, line 125
vtkEvenlySpacedStreamlines2D (0000017C53E8E7A0): vtkEvenlySpacedStreamlines2D does not support planes not aligned with XY.
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (0000017B05A8AEB0): Algorithm vtkEvenlySpacedStreamlines2D(0000017C53E8E7A0) returned failure for request: vtkInformation (0000017BA0016140)
Debug: Off
Modified Time: 29153292
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FORWARD_DIRECTION: 0
ALGORITHM_AFTER_FORWARD: 1
FROM_OUTPUT_PORT: 0
Respective if I use it on z-plane:
ERROR: In C:\bbd\8fbebceb\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 753 vtkCompositeDataPipeline (0000017AB5754D50): Algorithm vtkPVGeometryFilter(0000017BA0098320) returned failure for request: vtkInformation (0000017AE9B67870) Debug: Off Modified Time: 50048809 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA_OBJECT FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 FROM_OUTPUT_PORT: 0
My workflow for is so far:
-slice vertical or horizontal plane
- claculate with Calculator : U_XiHat + U_YjHat
- apply EvenlySpacedStreamlines2D
Do I need to do something else?
