How to plot time series at a fixed point for SPH simulation (.vtu) in ParaView
I’m visualizing an SPH simulation in ParaView using .vtu files with multiple time steps.
I would like to plot the time evolution of a variable ( like pressure or Z-variation because it’s a fluid simulation) at a fixed spatial point.
I tried using Probe Location and Plot Data Over Time, but I only get constant or zero values.
What is the best way to extract interpolated time series data at a given point in SPH simulations?
thank you in advance .
Please share your data.
i shared the .pvd files ( i think they are the same as the .vtu files )
(attachments)
boundary_1.pvd (33.2 KB)
fluid_1.pvd (31.7 KB)
You need to share the .vtu files too.
here i shared the .vtu files ( SPH files took a lot of time to be imported so i shared another files with the same prob)
You need to provide access to the file
sorry
https://drive.google.com/drive/folders/1IHZjdNilIUv8sivpSTItXyUhq_RW6f-E?usp=sharing
Works fine here, which version of ParaView are you using ?
version 5.13.3
Now I’m not sure if I used the filters properly , from the résults you got , is it possible to plot a simple graph of ‘H’ over the time in specific distance ?
Sure:
ProbeLocation + PlotDataOverTime
Here is a state file:
hplot.pvsm (437.6 KB)
it’s working now , thank you
