The data in XYZ format appears normal when viewed in other software, but displays incorrectly in ParaView.
How to solved this problem?
You are opening this file using a molecule reader (xyz is a popular molecule format). Use the correct reader for your data instead ?
For example, the Delimted Text reader.
I renamed the data with .txt/.csv extensions
but couldn’t open it properly using:
What should I do exactly?
please share your data.
data:
7000.xyz (233.7 KB)
Here is a statefile is that helps:
ttp.pvsm (197.2 KB)
