How to read VTKHDF5 in Paraview?
I am experimenting with VTKHDF files. I found an example called “test_poly_data.hdf”. (link here) When I try to load it in Paraview i get a pop-up window titled “Open Data With…” The dafault option is ADIOS2VTXReader.
I click OK and then Paraview crashes. How do I load VTKHDF files in Paraview?
test_poly_data.hdf (206.3 KB)
Its not, ParaView tells you that “A reader […] could not be foud”
You are probably using an old version of ParaView that does not have the VTKHDF reader. Please update.
Thank you, you are right, I was using Paraview 5.9. I tried Paraview 5.12 and it loads the file “test_poly_data.hdf” without any problems.
