How to render 3D bathymetry data
Hi,I am quite new to paraview, I’d like to use paraview for visualizing bathymetry data.
I have a netCDF file containing the lat, lon, and elevation ,
Like in this picture, I also want to do this.,
I use the‘Warp by scalar’,
However, this is not the same as I expected.
This is the result I got:
This is my nc file:
GEBCO_2019_131.0_35.0_134.0_32.0.nc
Can I get the results I expected with my current data?
I’m sorry for bad English.
Can you help me understand if this is possible.
Thanks for the help! :smiley:
I see two differences:
  • color
  • surface height
Are there other differences you see?
For the first problem, I recommend following Chapter 2 of the ParaView Tutorial, which addresses how to change the color map and gives you a very thorough understanding of how to use ParaView’s basic features.
For the second problem, adjust the Scale Factor setting in the Properties Panel to make it bigger or smaller.
Thanks for looking into this! I think i understand.:smiley:
You may also want to take a look into this blog :
