i found when i put several vtkImageData into vtkMultiBlockDataSet, i cannot select “Volume” representation.
It seems the output data type is “vtkMultiBlockDataSet” not “vtkImageData”, so in the paraview representation GUI, there is no “Volume” option to choose…?
How can i make such multi block image data to be rendered by volume representation?
Alas, volume rendering of any multiblock data is not well supported. As a not terribly efficient workaround, you can use a Resample to Image filter to enable volume rendering. It is definitely not ideal, but works in a pinch.
Merge Blocks would enable volume rendering, but it would greatly expand the memory footprint because all grids would be converted to unstructured grids. If you start with a multiblock of unstructured grids, then that’s not a big deal, but coming from image data it is a bigger deal.
