I would like to replace an old vtkPythonProgrammableFilter with a subclass of VTKPythonAlgorithmBase.
There was an XML specification file to expose that filter in ParaView and I would like to use some decorators to replace that file as described in this link.
I’m looking for some examples to replace part of that file.
- Do you have any hint to define a sub-menu with an enumeration of choices, as in the following XML code ?
<IntVectorProperty
name="geomOrigin"
label="Origin"
initial_string="geomOrigin"
command="SetParameter"
animateable="1"
default_values="1"
panel_visibility="advanced"
number_of_elements="1">
<EnumerationDomain name="enum">
<Entry value="1" text="One"/>
<Entry value="2" text="Two"/>
</EnumerationDomain>
<Documentation>Description...</Documentation>
</IntVectorProperty>
- Do you have any hint to create a checkbox, as in the following example?
<IntVectorProperty
name="verbose"
label="Details"
initial_string="verbose"
animateable="1"
default_values="0"
<BooleanDomain name="bool" />
- Is there any possibility to write the XML corresponding to a decorated class?
Thanks in advance.
Regards,
Loic
