I have a table of points, for example containing the following columns, x, y, z, density. I want to rotate and translate the density field but keep the co-ordinates (lattice), (x,y,z) the same. I’ve tried using the transform filter but this transforms all the columns. Is there a way to transform just the density field/ column?
Thanks,
James
