I compiled 5.6 superbuild version with EGL and MPI support on my linux machine. I have an instance with 4 GPUs and 24 cores but since I have EGL capabilities, I want to use all 4 GPUs. The following is a command I tried:
pvbatch --egl-device-index=0,1,2,3 post_scalar_V3.py
The issue is that upon reviewing the GPU usage, only the GPU with index 0 is being utilized. What’s the correct command to use all the GPUs in my machine? See the nvidia-smi output. As you see at very bottom, only one GPU is being utlized.
| NVIDIA-SMI 470.82.01 Driver Version: 470.82.01 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA A10G On | 00000000:00:1B.0 Off | 0 |
| 0% 29C P0 73W / 300W | 1717MiB / 22731MiB | 24% Default |
| | | N/A |
| 1 NVIDIA A10G On | 00000000:00:1C.0 Off | 0 |
| 0% 25C P8 18W / 300W | 0MiB / 22731MiB | 0% Default |
| | | N/A |
| 2 NVIDIA A10G On | 00000000:00:1D.0 Off | 0 |
| 0% 25C P8 10W / 300W | 0MiB / 22731MiB | 0% Default |
| | | N/A |
| 3 NVIDIA A10G On | 00000000:00:1E.0 Off | 0 |
| 0% 26C P8 16W / 300W | 0MiB / 22731MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 40294 G ...aview-egl-5.6/lib/pvbatch 1717MiB |
