Hi, I am trying to create a panel widget for a group property, In my pqInteractiveSettingPropertyGroup, I am trying to set the value of SettingA, do I need to use
auto settingA = vtkSMIntVectorProperty::SafeDownCast(this->smProxy()->GetProperty(“SettingA”));
or
auto settingA = vtkSMIntVectorProperty::SafeDownCast(this->smGroup()->GetProperty(“SettingA”));
(smProxy or smGroup)
<StringVectorProperty
command="SetSettingA"
default_values=""
name="SettingA"
number_of_elements="0"
number_of_elements_per_command="3"
repeat_command="1"
use_index="1"
command="SetSettingB"
default_values=""
name="SettingB"
repeat_command="1"
use_index="1"
<PropertyGroup label="Settings" panel_widget="InteractiveSettingPanel">
<Property name="SettingA" />
<Property name= "SettingB" />
</PropertyGroup>
I am asking this, because I used to directly set the panel_widget inside property SettingA and by using smProxy()->GetProperty(“SettingA”) I could modify the property but now using property group it isn’t working anymore.
or do I need to link the properties?
thanks you
