I do CFD with phase changes and I need to see what had been melted. The general goal is an comparison with micrographs from experiments. A heat source melts my material (a value changes from 0 to 1) and the material resolidifies (value goes back to 0).
So I need to be able to show all cells that had myValue=1 at any given time in one final result.
Any help on how to achieve this is appreciated!
Regards
Terry
Thank you.
So far i got Segmentation fault (core dumped). Was I doing to many things at the same time with two times paraview open and a pvpython script running?
There might exist a way to output an vtk set of the wanted cells via an openFoam function. That sure won’t be easy as well, though.
